source for PWK OKO Keihin rubber inlet couplers ?
johnny650
anyone know where I can buy a 30mm ID rubber carburetor coupling for the Keihin OKO PWK carb ?
Only thing I can find is silicon which is no good for fuel. :(
johnny650
cheers I'll check to see if they have a 30mm ID for a 24mm carb
Actually its crazy I know but it would be cheaper to buy another 24mm PWK carb and get a rubber coupling with it for £15.00
EddieStone
johnny650 wrote: ↑Fri Nov 23, 2018 1:48 am Actually its crazy I know but it would be cheaper to buy another 24mm PWK carb and get a rubber coupling with it for £15.00
I've found that out. Only because the carb is so cheap I guess. There's a hydralic hose supplier neaby and I've planned to find the right size hose and use that.
johnny650
I ended up buying some 30mm ID silicon hose on ebay for a temporary solution . i think I paid £3 for 4" inches so I cut it in half and made 2x !
I know that it is not fuel proof so it won't last long but it will allow me to test start and run the scoot for a while
