Page 1 of 4
Scooter not picking up properly ........... HELP!
Posted: Sun Sep 30, 2018 6:18 pm
by alanscottj
Ok, I have been trying to solve a little issue on my scooter for a few weeks now and have reached a point that I just can't get past. The issue is that the scooter nearly dies as I try to pull away - sometimes I have to slip the clutch a touch to get it to rev properly and pull away (once she goes, she flies!). Initially I thought it was jetting as that is what it feels like - like it's not getting enough fuel or it is too rich - but after a week or so faffing with jetting I took her to PSL and got her on the dyno. Amazingly, I had got the jetting spot on (thanks to Facebook help!) - the dyno operator tried for nearly two hours to sort the issue - he went both up and down on pilot, tried playing with air screw mix etc but couldn't fix the issue, it just dies on pulling away. There was a backfire whilst doing the dyno so we thought it might be electrical and gave up there. On the way home from Liverpool I called in at Flintshire Scooter Centre and bought a new CDI and they tested my stator and it gave excellent readings. Fitted new Cdi and the problem is still there. Once the scooter goes she goes perfect, it is just the initial pulling away that is the issue. This afternoon I thought I would check the timing just to rule that out - static timing bang on 18 and doesn't budge at all when I rev the engine. The engine spec is as follows:
Mugello 186 - no porting or anything
60x110 crank with 3mm packer plate
Anthony Tambs external pick up - set at 18 degrees
JL4 Exhaust
Dellorto 30mm carb - set up on dyno with 123 main, AV266, X7 top clip, 40 Slide, 60 pilot
AF cassette clutch
AF 5 speed box with 47x18
Any thoughts? Many thanks!
Scott
Re: Scooter not picking up properly ........... HELP!
Posted: Sun Sep 30, 2018 6:27 pm
by Scooterdude
My guess would be a failing lt coil or pick up. Remember if you test the lt coil it probably will read ok as you are actually testing the two resistors within the coil and not the coil itself.
Posted: Sun Sep 30, 2018 6:29 pm
by GeorgeS
Would a quick test be to swap to the stator pickup? 1 wire change and it might show a different behaviour.
Sent from my SM-G920F using Tapatalk
Posted: Sun Sep 30, 2018 6:34 pm
by alanscottj
Scooterdude wrote: ↑Sun Sep 30, 2018 6:27 pm My guess would be a failing lt coil or pick up. Remember if you test the lt coil it probably will read ok as you are actually testing the two resistors within the coil and not the coil itself.
Thank you Scooterdude :D
Posted: Sun Sep 30, 2018 6:35 pm
by alanscottj
GeorgeS wrote: ↑Sun Sep 30, 2018 6:29 pm Would a quick test be to swap to the stator pickup? 1 wire change and it might show a different behaviour.
You mean plug in the red from the stator - bypassing the external pick up?
Posted: Sun Sep 30, 2018 6:48 pm
by garry inglis
I've just had a bgm stator that showed correct ohms and my sip Speedo wouldn't work till 3000rpm swapped stator and worked straight away so tested the bgm again still showing ohms as it should be but something was breaking down
Posted: Sun Sep 30, 2018 6:50 pm
by GeorgeS
Yes, if you think your stator timing is reasonable it could be a quick test.
Posted: Sun Sep 30, 2018 6:57 pm
by alanscottj
GeorgeS wrote: ↑Sun Sep 30, 2018 6:50 pm
Tried it - no difference whatsoever - still not picking up properly as I pull away :roll:
Posted: Sun Sep 30, 2018 6:58 pm
by alanscottj
garry inglis wrote: ↑Sun Sep 30, 2018 6:48 pm I've just had a bgm stator that showed correct ohms and my sip Speedo wouldn't work till 3000rpm swapped stator and worked straight away so tested the bgm again still showing ohms as it should be but something was breaking down
Looks like I'll have to try another stator
Posted: Sun Sep 30, 2018 8:10 pm
by Scooterdude
When you charge your stator dont ditch the old one. Instead buy and fit a Ducati/Piaggio lt coil and pick up and keep as a spare.
