Page 1 of 2
GP tail light bulb blowing
Posted: Wed Sep 26, 2018 2:34 pm
by Mrnice71
Hi chaps
Im sick of the rear tail light bulb blowing on my GP 200 TS1 , dont have a problem with any of the other bulbs , is there a fix for this or is just down to vibration ? Wondering if the LED conversion would cure this ? Im running an AC stator ...cheers
Re: GP tail light bulb blowing
Posted: Wed Sep 26, 2018 2:52 pm
by johnny650
is it the tail light or the stop light filament thats blowing ?
Posted: Wed Sep 26, 2018 3:14 pm
by Mrnice71
Tail light Johnny mate
Posted: Wed Sep 26, 2018 4:29 pm
by Tractorman
If it coincides with you using the dip switch it could be that that's faulty. Or maybe a faulty connection that puts the headlight out long enough too blow the back light bulb.
Posted: Wed Sep 26, 2018 4:37 pm
by garry inglis
check your earths and you could have a brake in the loom also the led is a lot betteri would also check the rubber boot on the break pedal hasent
come off and the wires pulled out a bit
Posted: Thu Sep 27, 2018 7:20 am
by Daggs
Is this a 12v AC conversion or standard factory set-up.
Posted: Thu Sep 27, 2018 1:45 pm
by Mrnice71
Daggs wrote: ↑Thu Sep 27, 2018 7:20 am Is this a 12v AC conversion or standard factory set-up.
Its running a 12 v AC electronic ,daggs
Posted: Thu Sep 27, 2018 2:18 pm
by Daggs
In that case, I suspect there's a little too much voltage coming from the reg. and as 'tractorman' said. There is a momentary peak and the lamp filament blows.
Buy yourself a LED conversion bulb, it should cure it.
Posted: Thu Sep 27, 2018 5:24 pm
by Mrnice71
Right had rear light off ,cleaned up all terminals & earths ,try that if not LED it is , cheers guys !
Posted: Thu Sep 27, 2018 6:08 pm
by warts
Agree it is likely a voltage peak, but if it is caused by vibration, an old trick is to put two or three small dabs of silicone round the metal casing to act as a damper.
