Page 1 of 2
difficult neutral
Posted: Wed Sep 19, 2018 6:14 pm
by Daggs
Any thoughts appreciated.
Standard Li150 gearbox. Goes through the gears static. Goes through the gears when riding, except, finding neutral when slowing down. It's really difficult, end up struggling between first and second before double-handed wrench into neutral. :cry:
Re: difficult neutral
Posted: Wed Sep 19, 2018 6:53 pm
by garry inglis
Just slacken off on one or the other a few runs try that and a bit more if needed
Posted: Wed Sep 19, 2018 9:45 pm
by holty
do you have clutch drag ?
Posted: Wed Sep 19, 2018 10:52 pm
by Toddy
holty wrote: ↑Wed Sep 19, 2018 9:45 pm do you have clutch drag ?
+1 I would check that first
Posted: Thu Sep 20, 2018 7:08 am
by Daggs
It's not cables and the clutch is fine. keep the ideas coming :)
Posted: Thu Sep 20, 2018 8:28 am
by garry inglis
Headset off and see what's happening could be outer has come out of slot
Posted: Thu Sep 20, 2018 10:50 am
by Daggs
A bit more info. It's none of the obvious things. It's been like it since I built the engine over a year ago. Initially I thought (hoped) it would ease as the scooter was used. Perhaps a sharp edge in there somewhere was snagging? But no change after more than 1200 miles.
Posted: Thu Sep 20, 2018 1:14 pm
by garry inglis
Well I would take side off check the clutch and endplate off and check gears you might have 2nd gear with the boss the wrong way the tree could be chipped or worn
Posted: Thu Sep 20, 2018 3:18 pm
by holty
maybe the cursor is stiff on the layshaft, did you test fit it and made sure it would slide backwards and forwards freely, before the spring and balls where installed ?
Posted: Thu Sep 20, 2018 3:26 pm
by garry inglis
It definitely needs open heart surgery
