spaq front disc brake issue
Posted: Mon Sep 10, 2018 9:33 pm
hi peeps i need some pointers/advise on a "spaq/crap" front disc brake i've renovated a gp and now reassembling it
i've got an issue with the front wheel not sitting central in the forks
before disassembly there was an issue with the brake not working properly the caliper was sticking and causing brake judder the disc has a strange wear pattern too
the slides in it were all gauled up i've now noticed that the caliper mounting plate isn't sitting parallel with the disc
also the new sip tubeless rim is about 8mm offset to the flywheel side of the scooter
has anybody had this ? if so what did you do to fix it
do i need another disc kit if so what are your recommendations ?
thanks in advance
thanks in advance
