Hello from Belgium
Posted: Fri Aug 31, 2018 1:19 pm
Hello,
Last year bought myself a Lambretta, seemed to be a Serveta LI 150 Special from 1980, scoot was quite original but had some problems with the engine (worn engine).
I replaced the piston cilinder and head and put a new clutch in been running without problems since.
Changed the 18mm carb for a 24mm and changed the 42mm clubman for a slightly bigger expansion exhaust, does 60 Miles/Hr for the moment on the GPS.
Took her to the VWD in Belfast and we had a great time over there, took her to Normandie for a week in August and had no problems at all. Will be going to the BVD next weekend and hope to see some of you over there. Also planning to go to Hungary WVD next year.
Regards Jurgen
Regards Jurgen
