Page 1 of 5
S2 Eibar wiring diagram.
Posted: Mon Aug 20, 2018 12:33 am
by wrecklessrobbie
Can anybody point me in the right direction to find a wiring diagram for an Eibar s2.
I am using the original light switch and cut out switch and connector blocks in the headset.
I have fitted a new AF wiring loom and 12v electronic stator, regulator and cdi.
The light switch colours seem to be different to Italien and am wondering where the new AF loom cables go.
Robbie
Re: S2 Eibar wiring diagram.
Posted: Mon Aug 20, 2018 8:58 am
by HxPaul
Try Antony at Buzzsolomoto.
Posted: Mon Aug 20, 2018 7:38 pm
by wrecklessrobbie
Ok
Its the af wiring loom thats confusing me.
That has grey, brown,black and green.
Im thinking green should go to connector block and cut out switch.
Not sure on the others
Posted: Mon Aug 20, 2018 7:52 pm
by mick1
not 100% but the black is usually the back light, the brown is the lighting feed, agree about the green and the grey ......hmmm not sure ?
Posted: Mon Aug 20, 2018 10:10 pm
by wrecklessrobbie
I shall look at the wires going to the back light and brake light.
I have wired them up. I suspect your right with the black. But need to check what i have done!!!
Trying to remember if grey was from the back brake.
Grey is back brake.
Black is back light.
Brown is running from regulator.
Green from cdi.
Posted: Tue Aug 21, 2018 9:32 am
by HxPaul
http://www.afrayspeed.co.uk/index.php?p ... ectricThis is an AF Rayspeed wiring diagram for a 12v system(this is for a series 3 with an ignition switch)and it shows clearly the grey wire in the loom and from what I can see it goes to the brake light switch.If you click on performance and scroll down,then click on electronic kit instructions.
Posted: Tue Aug 21, 2018 10:54 pm
by wrecklessrobbie
Yeah i have looked at the af wiring diagram paul.
Grey is brake
Brown feed from regulator
Green from cdi
Black from rear light.
So far i know green connects to kill switch on connection block
Not sure where grey brown and black go yet.
Posted: Wed Aug 22, 2018 8:38 am
by rosscla
What wires are coming from the switch?
Posted: Wed Aug 22, 2018 10:29 pm
by wrecklessrobbie
Cut out switch is green.
Light switch..
Has
Long single white...horn i think.
Yellow...sidelight i think
Red...headlight dip or main
Blue...headlight dip or main
Green
Grey
Black
Brown
Junction box has
Grey 3 holes
Blue.2 holes
Black 3 holes
Brown 3 holes
Green 2 holes....for cut out switch and green from cdi??
Light bulb holder has 4 holes
I think for blue, earth yellow and red?
Posted: Thu Aug 23, 2018 6:02 pm
by rosscla
Id start by connecting the colours at the headset end
Blue/red will be your dip /main
Yellow to your sidelight
Loom - switch
Brown - Brown
Black to black
Grey to grey
Black also to speedo bulb
Not so sure about the green from the switch though.
