BGM CARB
Posted: Tue Aug 14, 2018 10:16 pm
by Hotdog
Will their be any benefit fitting a bgm fast flow carb to a PX200 with a sip2 exhaust ? The scooter is to be used as a rally going scoot, so plenty of motorway miles to be undertaken at full throttle.
Re: BGM CARB
Posted: Wed Aug 15, 2018 12:39 pm
by Bofs
No need, I have the same set-up as yourself and on the open road I only use full throttle if I`m on my own, never any problems with fuel starvation.
Re: BGM CARB
Posted: Wed Aug 15, 2018 4:22 pm
by Hotdog
Have you the carb jetting to hand ?
Re: BGM CARB
Posted: Wed Aug 15, 2018 11:24 pm
by Muttley McLadd
Are you replacing the carb for some other reason anyway?
Re: BGM CARB
Posted: Thu Aug 16, 2018 7:23 am
by Hotdog
No, was just worried about fuel starvation.
Re: BGM CARB
Posted: Thu Aug 16, 2018 11:45 am
by cartmel808
No need to change your carb - but you will need to up your main jet by a couple of sizes over standard (if you haven’t already done so).
On my Rally 200 with sip 2 pipe I run a 120 main jet & drilled filter - whilst a mates P200 with same pipe runs with a 122 mj & drilled filter... no fuel starve issues & both can sit happily at WOT till the fuel runs out.
Re: BGM CARB
Posted: Fri Aug 17, 2018 8:31 pm
by Hotdog
Thanks that’s reassuring to know
