Reverse pull front brake outer cable length
db67
Hi, just wondered if anyone knows what length to cut the outer cable? it's going to be used on a lambretta series 1. many thanks ;)
EddieStone
I did this on my chop. The best method is to cut it longer than you need and trim it back bit by bit. Bit of a faff but it doesn't take that long.
db67
Cheers ;)
