leg shield wheel holder
Posted: Fri Aug 03, 2018 8:52 pm
by dennis
Just fitted spare wheel holder on GP and the wheel hits the leg shields before seating properly,i know the GP has more of a curve than LIs etc,has anyone else had this.
Re: leg shield wheel holder
Posted: Fri Aug 03, 2018 9:12 pm
by Doom Patrol
It'll do it on all of them. It depends what sort of holder you have and what shape it's in as to how it sits. You might possibly be able to bend the legs a little if there is enough room for adjustment. Or, depending how long your bolts are, you might try putting a nut behind the wheel to bring it out a little more.
Posted: Fri Aug 03, 2018 11:43 pm
by rosscla
Another option is to put long nuts, like the cylinder head spacer nut, on the holder and use bolts to attract the wheel.
Posted: Sat Aug 04, 2018 7:11 am
by dennis
long nuts and studs it is then,thought i would have to do some thing like that.
Posted: Mon Aug 06, 2018 4:17 pm
by Timbo
Just had my studs welded longer so that I can fit SIP rims plus the oil holder. I tried the extension nuts and studs but the wheel sat too far forward. Bolts available if you want them Dennis,plus studs if I can find them.
Posted: Mon Aug 06, 2018 5:43 pm
by dennis
sorted now Timbo ,although you could be right about bringing it forward to far, still building it at mo wont know till start riding it.
