Page 1 of 3
pacemaker box
Posted: Wed Jan 14, 2009 1:33 am
by byron
I've got an Li150S gearbox that has the centre of the tree drilled for the clutch.
Does this mean it's the early type, and shouldn't be used on a more powerful engine ?
Or is that distinction based upon measuring across 5 teeth of 3rd [?] gear ?
thanks again
Re: pacemaker box
Posted: Wed Jan 14, 2009 7:25 pm
by mickyb
It's the third gear, you want thick one
Re: pacemaker box
Posted: Wed Jan 14, 2009 7:50 pm
by 2wheeldeal
does anyone know the measurement?
Re: pacemaker box
Posted: Wed Jan 14, 2009 8:14 pm
by johnd
Ask "ketje" on here, he has used the third gear from an sx box with a drilled pacemaker box and has had very good results, still going strong in his TS1.
Re: pacemaker box
Posted: Wed Jan 14, 2009 8:35 pm
by mickyb
3rd gear across 5 teeth, early 33mm, late 33.8mm. You cant use the early xmas tree with the later 3rd gear, you need the complete set
Re: pacemaker box
Posted: Wed Jan 14, 2009 9:13 pm
by joespeed
are there any other gearboxes across the range that can be miss-matched to make a better ratio,i tried this many years ago but it growled and i swapped the cut down/scrambler for a nice tv200 so cant remember what the long term was.
regards
joe
Re: pacemaker box
Posted: Wed Jan 14, 2009 10:43 pm
by byron
mickyb wrote: You cant use the early xmas tree with the later 3rd gear, you need the complete set
ah, thanks that was my next question.
johnd wrote:Ask "ketje" on here, he has used the third gear from an sx box with a drilled pacemaker box and has had very good results, still going strong in his TS1.
but you can use the SX150 39 tooth loose gear
i do like the idea of the drilled tree, gotta be good for clutch action
Re: pacemaker box
Posted: Wed Jan 14, 2009 10:44 pm
by jonny snatchsniffer
the strong type does not have the hole in the christmas tree. the pacemaker (early) is also the same as a late 125 series 3 box which has the weaker 3rd with the hole in the tree tho i doubt you will break it unless you have a mad engine or are racing.
Re: pacemaker box
Posted: Wed Jan 14, 2009 10:48 pm
by RinB
Re: pacemaker box
Posted: Wed Jan 14, 2009 10:49 pm
by byron
jonny snatchsniffer wrote:... i doubt you will break it unless you have a mad engine or are racing.
cheers, that's what i was thinking... it's going in a [probably about] 230cc, but nothing too mental. I only have one scoot and like to keep it on the road.
