Uber race crank
Posted: Tue Jan 06, 2009 11:41 pm
This is the mild 'flow assisted' version......a somewhat more extreme 'full race cut' version is in the pipeline for my RB20 build.....full write up to follow:
The UK's No1 Lambretta & Vespa Scooter Forum.
https://www.scooterotica.org/forum/
It is.RobD wrote: I agree that you'll lower primary compression if that's what you're aiming for.
Yes, we intend to do the race version as a 'bell' shape, following the contours of the weighted end of the crank circle. So the remaining mass is opposite the rod/pin ....like a couterbalance?RobD wrote: There's a limit to the amount of rotating mass you want to remove otherwise there won't be enough inertia to keep the engine going between power strokes and it won't tick over as I'm sure you'll know.
Of course.RobD wrote: In my mind as much of the weight removed as possible should be removed from the flywheel therefore reducing the stress on the crank pin / web interface.
I always make this mistake (not emphasising the end use)......the full race version is letteraly that....full race, so tickover is of lesser concern, its revs and power that we are interested in.RobD wrote: I suppose what I'm trying to say is that if I know I can take a kilo off the rotating mass before the engine becomes erratic at tickover than I'd rather take off all the kilo from the flywheel than say 750g from the flywheel and 250g from the crank webs. Minimise the stress on the crank.
Lots of things are 'apparently' sufficient.....but it depends how far you're taking the rest of the tuning before it becomes a weak link and needs further consideration.RobD wrote:I still can't see that you're going to get appreciably better gas flow but will be interested in your findings. A better big end bearing is apparently sufficient for the RB225/250.
[/quote]drunkmunkey6969 wrote:Yes, we intend to do the race version as a 'bell' shape, following the contours of the weighted end of the crank circle. So the remaining mass is opposite the rod/pin ....like a couterbalance?RobD wrote: There's a limit to the amount of rotating mass you want to remove otherwise there won't be enough inertia to keep the engine going between power strokes and it won't tick over as I'm sure you'll know.
Can make it a bit more difficult to ride though, don't forget driveability (tractability?) might make you quicker round the track than outright power.drunkmunkey6969 wrote:I always make this mistake (not emphasising the end use)......the full race version is letteraly that....full race, so tickover is of lesser concern, its revs and power that we are interested in.RobD wrote: I suppose what I'm trying to say is that if I know I can take a kilo off the rotating mass before the engine becomes erratic at tickover than I'd rather take off all the kilo from the flywheel than say 750g from the flywheel and 250g from the crank webs. Minimise the stress on the crank.
