Spark Plug Check
parky
Mon Jul 09, 2018 5:33 pm
Having checked my plug after a run of about 15 miles it looked quite a bit lean. I have checked for air leaks and could find none. I have adjusted the mix screw slightly and have now cleaned and refitted the existing spark plug. How many miles will I need to do before a plug chop would give me a good indication of the current situation? I have done a chop after a couple of miles but the plug is still very clean and giving me no indication either way as yet.
garry inglis
ebay user ID: garry52uk
Main scooter: 64 silver special rb200
Mon Jul 09, 2018 5:42 pm
What you need to do is put masking tape on the throttle side and Mark 1/4 1/2 3/4 and full throttle or wo wide open go for a run to warm the scoot up and try and find a stretch of road with a slight incline ride around at each setting and check the plug at each setting and this will show what throttle setting is lean it's a mess about but it's the only way unless you get it dynod witch I would recommend
