Shock Absorber eye to stud sizes issue
Posted: Sat Jun 30, 2018 10:08 am
by loadedscooterist
Hi All,
I have been doing further bits to the scooter - this time a replacement for the shock absorber. However, I have encountered a strange issue. The eye of the shock top and bottom wont fit onto the studs/lugs as the eye is too small to fit onto the lug. When I measured the two the difference is approx 1-1.5mm out (i.e. The eye hole is 18.5mm and the stud looks approx 20mm (so it will never fit even with grease!).
I spoke to the supplier of the shock and he had a similar issue not long ago where a shock wouldn't fit the lug on a particular scooter but fitted on others fine. Has anyone else encountered something like this before and what did you do about it?
I have thought about getting a step drill bit and making it slightly larger so it fits. Good idea or bad?
Re: Shock Absorber eye to stud sizes issue
Posted: Sat Jun 30, 2018 5:30 pm
by holty
i have seen the inside sleeve rusted onto the frame shocker mount, that would have stopped the shocker fitting, does it fit on the engine ?
Posted: Sat Jun 30, 2018 9:29 pm
by loadedscooterist
No that's the odd thing. The actual lugs are in good shape, no rush. Just a bit big....
Posted: Sun Jul 01, 2018 4:16 pm
by boxofbits
Cheers may try a diffrent piston, reed valve would work i think but would need a piston with holes in it i think
Posted: Sun Jul 01, 2018 5:20 pm
by mick1
boxofbits wrote: ↑Sun Jul 01, 2018 4:16 pm Cheers may try a diffrent piston, reed valve would work i think but would need a piston with holes in it i think
My thinking as well :shock: if it's the rear shocker try a different piston.......
Obviously posted on the wrong thread but amusing all the same.....
Posted: Sun Jul 01, 2018 6:07 pm
by Timbo
Posted: Sat Jul 14, 2018 6:42 pm
by ringwoodrob
I've had it the other way with fitting a new Indian Escort shock there was too much slack in bush sleeve to lugs resulting in massive vibes through whole scoot felt like engine mounts had gone!!!!!!!!!!
