Help!! Keep breaking reed petals in a TS1
Posted: Tue Jun 26, 2018 2:11 pm
Any ideas appreciated before I set fire to this scooter...
I’ve just destroyed either the 4th or 5th set of reeds in a year, I’ve lost track! I haven’t even taken the reed block off this time, I just know what the problem is
TS1 with MB Race Tour tune it’s been on two different engines, one with a 58/110 crank the other a 60/110. I’ve had three different exhausts on it, all expansion types, and always with a TMX35. Standard reed block and vetronite petals.
First time a definite back fire did it, not noticed one since. Twice the petal has had a chunk blown out the middle (this stops the scooter dead) twice the petal has had fraying at the bottom or little bits of the corners; runs like this just very rich. Definitely five sets then because I haven’t checked this occurrence.
Pretty sure no electrical issues and backfire, apart from the first time. Squish is quite low on current engine from memory about 1.13, could this be a factor?
What about solutions? Can you double up reed petals on a TS1? Would a reed stuffer/packer help? I looked at V Force reviews and think the reeds may be even weaker. The BGM Yamaha reeds look less brittle but you need a 3mm packer with the block and I don’t have that spare under the frame.
Thanks Mark
Thanks Mark
