series 2 breakdown
jbg584
Main scooter: Lambretta 1960 series 2
Just back from IOW rally on my series 2 original engine. Had a few problems same thing each time after about 5 miles she just stops, actually it happened 4 times not seized as still kicked over but wouldn't start put in new plug started went then 5 miles approx stopped again some lads even tried bumping no go waited 10 minutes or so started first time then approx 5 miles stopped.I think it got just to hot have you or any of the lads got any ideas
Daggs
The old fuel cap blockage comes immediately to mind.
Martin20
Main scooter: Lambretta LI 150 Special
Condenser on its way out? Had similar issue on mine, cutting out when it got hot!
jbg584
Hi will check condenser cheers
Timbo
Stator...?
jbg584
Hi changed condenser and new plug and points took her out for the first time in a while still exactly the same just dies out after 5-8 miles have to wait 15 min and she will go fine
    Users browsing this forum: Amazon [Bot], Google [Bot] and 1 guest
