Vespa PX speedo drive retaining bolt
Posted: Wed May 30, 2018 12:35 am
by Hedges
The small bolt at the forks has snapped and refused to come out. I tried drill so I could tap it again but it started to go offline.
Question is can I wedge in the metal barrel and rubber bung so to keep the drive in place. Is there much force when spinning and will this just pop them out? Cheers
Re: Vespa PX speedo drive retaining bolt
Posted: Wed May 30, 2018 12:06 pm
by Norrie Bodge
If you’ve already drilled & it’s past the stage that you can’t get an easy out on it?
Use a stainless self tapper screw to hold the retaining plate in position
GL
