Reed valve crank clearance
hungdog
Tue May 29, 2018 5:17 pm
Does it matter what the clearance is on reed cranks against the housing outside edge of crank ? ie thin edges.
If i had the housing enlarged to 100mm diameter and then used a standard reed crank would it work ?
hungdog
Wed May 30, 2018 5:22 pm
anyone ?
Grumpy225
ebay user ID: Grumpy225
Wed May 30, 2018 7:53 pm
"the housing outside edge of crank" More info would be helpful here.
What's a "standard reed crank"? Is that like a stock hot rod?
If I had to render a guess, is this for a vespa?
Not trying to be difficult here but the details are important if you want actual relevant help.
