Leak down test spark plug
Posted: Sat May 26, 2018 8:57 am
by Mrnice71
Hi guys ,any good ideas on sealing the spark plug in a leak down test ? got a small leak .Need to address this permanently also
Re: Leak down test spark plug
Posted: Sat May 26, 2018 9:10 am
by holty
have you tried tightening it a bit more, the aluminium crush washer should seal it unless your head has a defect, maybe try a new plug, could try a little bit of silicone around the washer, but not too much you might seal it in for good,
Posted: Sat May 26, 2018 12:51 pm
by ForemanBob
I'd try a new plug an crush the washer down to suit.
Failing that a little grease to try to create a seal...
But if its that bad i'd be looking to get the seat machined flat..
Posted: Sat May 26, 2018 2:39 pm
by Mrnice71
Its a brand new head and new spark plug guys , manages to seal it with a fibre washer while l do the test which it passed :)
Posted: Sun May 27, 2018 4:18 pm
by garry inglis
when i built my ts1 engine i put the champion plug in that rayspeed recommends and did my leak test all ok apart from that plug changed to ngk and no more leak never used a champion since
Posted: Sun May 27, 2018 8:34 pm
by Mrnice71
garry inglis wrote: ↑Sun May 27, 2018 4:18 pm when i built my ts1 engine i put the champion plug in that rayspeed recommends and did my leak test all ok apart from that plug changed to ngk and no more leak never used a champion since
This was a NGK Gary .
Posted: Mon May 28, 2018 6:07 am
by garry inglis
Try a another plug and test and when that's ok test another one and keep as a spare as once engine is in the bike we really don't test them anymore
