Page 1 of 2
Funny noise then kickstart locked - then went ok???
Posted: Tue May 22, 2018 9:30 pm
by alanscottj
Just having a spin on the scooter - doing about 70 - heard a weird noise so pulled over - couldn't see anything wrong so went to go - kickstart locked solid - put it into gear and moved her back and forth - could feel piston move but kickstart still locked solid - a few minutes later tried ti kick her again and she kicked over and rode home perfect, like nothing happened, no lose of power or anything. Got home and I can definitely hear a knocking sound coming from flywheel area on tickover.
Any thoughts???
Re: Funny noise then kickstart locked - then went ok???
Posted: Tue May 22, 2018 10:01 pm
by coaster
Very possible that a stator bolt or something has come undone and is catching in the flywheel. DO NOT try to start it again or you risk destroying the stator....I speak from experience :oops:
Best get the flywheel off and have a look.
Posted: Tue May 22, 2018 10:35 pm
by alanscottj
coaster wrote: ↑Tue May 22, 2018 10:01 pm Very possible that a stator bolt or something has come undone and is catching in the flywheel. DO NOT try to start it again or you risk destroying the stator....I speak from experience :oops:
First thing I took off - nothing untoward there :?:
Posted: Wed May 23, 2018 1:30 am
by Grumpy225
I hate those kind of problems. Sounds like its case cove time.
Posted: Wed May 23, 2018 8:42 am
by HxPaul
When you took the flywheel off,did you make sure there were no metal objects attached to the magnets.
Posted: Wed May 23, 2018 4:56 pm
by garry inglis
kick start spring snapped or pin has come loose in kickstart piston
Posted: Wed May 23, 2018 8:55 pm
by Fux
You have PM. Please don`t use the scoot before you read it.
Posted: Fri May 25, 2018 9:24 am
by Fux
Had a look yet?
Posted: Fri May 25, 2018 10:08 am
by HxPaul
Fux wrote: ↑Wed May 23, 2018 8:55 pm You have PM. Please don`t use the scoot before you read it.
Is this a secret?
Posted: Fri May 25, 2018 11:03 am
by Fux
If he confirms that it is what I think it is, no.
