Black sooty oil from exhaust
Posted: Fri May 18, 2018 7:30 pm
by Strummer10
Guys any idea what a black sooty oily smoke from my clubman might be caused by ? Running a TS 1 at 3% oil ?
Re: Black sooty oil from exhaust
Posted: Fri May 18, 2018 7:42 pm
by drunkmunkey6969
Worn oil seal
Posted: Fri May 18, 2018 7:44 pm
by Strummer10
Would that not empty out the gearbox though over
say 200miles ?
Posted: Fri May 18, 2018 7:46 pm
by Strummer10
Is it prudent to stick a cloth over the exhaust see if it cut out, or would that cause a good seal to blow ?
Posted: Fri May 18, 2018 7:52 pm
by Strummer10
Thanks for response........Sorry could not edit the above posts, but I normally associate a blown drive side seal with clouds of white smoke and no gearbox oil, or very little.
Posted: Fri May 18, 2018 8:03 pm
by Grumpy225
The only time I've seen black smoke is when the mag side seal gave up and was washing the grease out of the bearing.
Posted: Fri May 18, 2018 8:40 pm
by Strummer10
Grumpy225 wrote: ↑Fri May 18, 2018 8:03 pm The only time I've seen black smoke is when the mag side seal gave up and was washing the grease out of the bearing.
Must confess it does clear after I get going. Before I do a full strip down, what tests can I do folks ?
