Winter model Date
Posted: Sun May 13, 2018 9:36 pm
by wintermod65
Hi all ,
Im coming to the end of my S2 Winter model build and and have got to apply for a dating cert , thing is my frame number is one of the higher than shall we say widely thought for the 64-65 period as its "666xx", it has the matching engine number on the original engine , although it currently has a GT240 on intercontinental casings fitted.
so how can i be certain that the date it will be given will reflect its true age and that ill not just be given the default for the winter model build period ?
the spanish reg number was V225-046 so from what ive found from valencia region , is there a spanish website where i might find out any info
any help be appreciated
Re: Winter model Date
Posted: Mon May 14, 2018 3:09 pm
by HxPaul
Cotact Buzzsolomoto,the owner Anthony knows Spanish Lambrettas better than almost anyone.
Posted: Mon May 14, 2018 7:48 pm
by hendy
The models starting 066 were built in 1966. I have one and know of a few others. If you get a dating certificate from lcgb it will show the correct year. Well mine does anyway.
Posted: Thu May 17, 2018 9:56 pm
by wintermod65
hi thanks for advice ,
mine came from buzz it came with a british lambretta archive dating cert which put it at 65, but that was back in 2014. i had seen some info regarding issue of high frame number winter models (latest ive seen is a 668xxx that totally scooters had although it didnt have original engine with it ) being built after 64-65 so wondered if mine was after these dates too
Posted: Fri May 18, 2018 5:50 am
by hendy
wintermod65 wrote: ↑Thu May 17, 2018 9:56 pm hi thanks for advice ,
Mine is a 668xxx. Bought direct from spain so there are at least 2 of them in UK
Posted: Fri May 18, 2018 11:39 am
by wintermod65
hendy wrote: ↑Fri May 18, 2018 5:50 am
Nice!! is it a 150 too ? im wondering whats the youngest known 'winter' about did any make it to the 70xxx . does yours have the "deep step" bridge piece mine was a bit rotty but used a repro S2 one as a repair section so managed to save it.
Posted: Fri May 18, 2018 11:40 pm
by hendy
wintermod65 wrote: ↑Fri May 18, 2018 11:39 am
Mine is a 150 (or was at least). I've no idea about the bridge piece as it didn't have one when I got it
Posted: Sat May 19, 2018 9:59 am
by wintermod65
The step is at the front of the bridge piece where the front rubber goes under its nearly 10mm deep on mine have seen same on a winter that was over at "discodez's" too and on the 668xx frame number one totally scooters had up on ebay i think they are peculiar to the winters as not seen them on pics of the regular spanish S2's .
i have seen a serveta owners group on facebook but just wondering if theres one for the lambretta locomociones / eibar S2's and Winter models.
