Which slide is the richest?
Posted: Fri Apr 27, 2018 1:30 pm
by Snails
Using an SH1/20 and looking to make the fuel mix a bit richer lower down the throttle position
Looking at the slides available on SR and there are
5914/1
5914/2
7895/1
7895/2
slides available. Based purely on the reasoning that the 7895/1 is for the GP200 and therefore likely to be the richest I'm guessing that in order or richness they would be ordered
7895/1
7895/2
5914/1
5914/2
From rich to weak?
Probably totally rubbish so any help on that appreciated!
http://www.scooterrestorations.com/lamb ... -3-and-gp/
Re: Which slide is the richest?
Posted: Fri Apr 27, 2018 1:57 pm
by Doom Patrol
Yes, that's basically it. One is richer than two. In both cases the 2 will have a larger cut out.
Posted: Fri Apr 27, 2018 2:23 pm
by Snails
Thanks , so is there is a difference between a 5914/1 and a 7895/1 then in terms of richness?
I have a 5014-1 fitted at the moment so I want to know if changing to one of the slides above will make a difference?
Posted: Fri Apr 27, 2018 4:24 pm
by HxPaul
Posted: Fri Apr 27, 2018 4:27 pm
by Doom Patrol
Snails wrote: ↑Fri Apr 27, 2018 2:23 pm Thanks , so is there is a difference between a 5914/1 and a 7895/1 then in terms of richness?
Other than the fact that one is for a 22mm carb and the other a 20mm.
Posted: Fri Apr 27, 2018 4:31 pm
by HxPaul
The 7895 is for the SH/22 carb and the 5914 is for the SH/20.The 5914-1 is the richest slide for an SH/20 carb,according to the Cambridge Lambretta site.
Posted: Fri Apr 27, 2018 4:46 pm
by Snails
Thanks all. So looks like I have the wrong slide in as nothing on the Cam Lam list has 5014-1, so I'll have a look for one of the ones listed but it probably wont make much of difference richness wise but you never know.
(mine is a Lui 50 running a Centro barrel bored out to 125 with an SH1/20 so cant just take the standard and will need to experiment)
