tv175 ser 2
Posted: Fri Apr 20, 2018 10:27 pm
by li mick
came to fit a delorto sh2/22 carb onto a standard rebuilt ser2 tv175 and found it wouldnt fit.
the o/d of the manifold is 30mm and the i/d of the carb is 30mm with the plastic reducer in,
just wondering if the manifold is standard as i never checked it before fitting cowling and putting in scooter.
any advice welcome,thanks.
Mick.
Re: tv175 ser 2
Posted: Sat Apr 21, 2018 9:08 am
by Daggs
I've had that problem in the past. I've also had them very loose fits.
I think it's just down to poor machining.
Just rub the manifold down a bit and use 2T on it when fitting the carb.
Re: tv175 ser 2
Posted: Sat Apr 21, 2018 1:59 pm
by vegansydney
I used a TV/2 manifold and swapped the bushing in the SH2/22 for a TV/2 type (available from Dell'orto UK). As the curvature of the TV/2 manifold (and LI/2) is different to the S3 type it also means you won't have to trim your cylinder cowl for it to fit.
Alternatively, use a GP manifold, but be prepared to trim cowl.
Re: tv175 ser 2
Posted: Sat Apr 21, 2018 2:13 pm
by li mick
thanks both much appreciated.
Re: tv175 ser 2
Posted: Sat Apr 21, 2018 2:33 pm
by Doom Patrol
I'm running a 22mm carb on my TV175 S2. I used a Scootopia GP manifold and I don't think any cutting of the cowl was involved.
Re: tv175 ser 2
Posted: Sun Apr 22, 2018 8:58 am
by li mick
i have looked for one of these carb bushes and cant find any,can anyone find a link,thanks.
Re: tv175 ser 2
Posted: Sun Apr 22, 2018 12:38 pm
by Doom Patrol
