Atomiser modification
Posted: Sun Apr 01, 2018 10:13 am
by Scooterdude
Got a AS 266 atomiser drilled out to 267 by Harry Barlow, problem is its an AS and not the shorter AV was thinking of turning it down to the same length as the AV, anyone tried this? Or is there more to it like an internal taper ?
Re: Atomiser modification
Posted: Mon Apr 02, 2018 11:20 am
by Scooterdude
Am guessing thats a no then.
Posted: Sat Apr 07, 2018 2:52 pm
by spannerman
As you have already said it been bored /drilled/reamed out by Harry Barlow ,so why would it be tapered, the difference between an AV and an AS atomiser is the height and can be altered easily
Posted: Sat Apr 07, 2018 4:00 pm
by Scooterdude
spannerman wrote: ↑Sat Apr 07, 2018 2:52 pm As you have already said it been bored /drilled/reamed out by Harry Barlow ,so why would it be tapered, the difference between an AV and an AS atomiser is the height and can be altered easily
Yes quite obvious i guess I should have saw that eh? Anyway i altered it to suit but still a bit on the rich side so gone back to AV266.
