Will this work ?
Posted: Fri Mar 30, 2018 11:03 am
by nellyboyo
Have been accumulating bits for my TV rebuild and I know everyone talks about how important matching this to that is etc etc so ........I was going to use ....as I want standard- ish looks . ( but want to use the motorway ) -
the MB Indian 215cc top end
24mm Jetex running through a modified air box
5 plate MB clutch
Standard TV200 gearing
Some form of clubman ( not yet acquired )
Tameini OR GT 60-100 crank with packer ....
Am I right in saying that anything larger than a 60mm will need the cases modifying ...and I don`t want that ....
cheers for any info
Re: Will this work ?
Posted: Fri Mar 30, 2018 11:22 am
by Norrie Bodge
nellyboyo wrote: ↑Fri Mar 30, 2018 11:03 am Have been accumulating bits for my TV rebuild and I know everyone talks about how important matching this to that is etc etc so ........I was going to use ....as I want standard- ish looks . ( but want to use the motorway ) -
5 plate MB clutch
cheers for any info
using the 60 x 110 Tameini crank will prob need the crancase troughing out m8, did on one of my Indian casings with a TS1 build
Posted: Fri Mar 30, 2018 11:37 am
by garry inglis
You will be fine with the gt60x110 as the big end and rod turn within the crank webs
Posted: Fri Mar 30, 2018 12:45 pm
by nellyboyo
Cheers boys , thats the stuff I need to know before I buy ...
