Page 1 of 2
Rear brake light
Posted: Tue Mar 27, 2018 8:15 pm
by Blenks
Got the point of my rebuild to get the scooter running. Checked all the lights and Everything is working fine except the rear brake light. Is it likely to be the switch if everything else is OK? Or could it be something else?
Re: Rear brake light
Posted: Tue Mar 27, 2018 8:29 pm
by YAMLAM
switch or, dont laugh, been there recently , duff new bulb.
Posted: Tue Mar 27, 2018 8:33 pm
by garry inglis
Is the light working or just when you push the brake on that's not working as what can happen is if you look underneath at the brake switch and press the brake the plastic cover gets pulled off and pulls the wires out I put a ty wrap round mine or a new bulb
Posted: Tue Mar 27, 2018 8:52 pm
by Blenks
I have fitted an MB LED rear light unit so not the bulb. The light is working with the head light just not when the pedal is pressed. I will have a check on your suggestion Garry tomorrow afternoon. Thanks for the quick replies all.
Posted: Tue Mar 27, 2018 9:15 pm
by Norrie Bodge
Blenks wrote: ↑Tue Mar 27, 2018 8:52 pm I have fitted an MB LED rear light unit so not the bulb. The light is working with the head light just not when the pedal is pressed. I will have a check on your suggestion Garry tomorrow afternoon. Thanks for the quick replies all.
Fitted one of these to a mates S2
& has the exact same issue?
We Found the LED rear unit had a blown resister ?
A mate tried a new resister but
no joy = BIN
Posted: Tue Mar 27, 2018 11:26 pm
by Grumpy225
https://www.superbrightleds.com/moreinf ... ofit/2625/
Pretty much any auto parts store will sell them.
I gave up on those LED boards a long time ago. I'm all for supporting the shops but some products are just not a good design.
Posted: Wed Mar 28, 2018 9:38 am
by HxPaul
Got one of these in my series 3,had it in for years,works perfectly.https://www.ebay.co.uk/itm/12V-Stop-and ... SwxCxT9ggF
Posted: Wed Mar 28, 2018 9:51 am
by Blenks
I actually replaced the one Paul has shown with the BGM LED unit. Hopefully it is just the switch and not as mentioned earlier the resistor issue. These parts aren't cheap and I have had to replace enough crap parts that were fitted by the person who had a go at restoring it before I bought it. So I don't want to have to replace the new ones I'm fitting. I've tried to fit the best parts that I can. Just goes to show that price is no guarantee of quality.
Posted: Wed Mar 28, 2018 10:35 am
by Daggs
Save yourself a lot of time trouble and expense mate.
Rig up standard bulb and test it like that. If it works then the fault may well be the led board. If it doesn't work, you need to trace back the wiring to the switch.
Be aware the rear light is usually 5W and the brake light 15W. If you cross these the 15w brightness will smother the 5w .
Posted: Fri Mar 30, 2018 4:52 pm
by Blenks
Brake light issue sorted. The two coonectors to the switch had pulled out at some point. Had to replace one of the connection bullets but all sorted.
