Fork damper washers and disc hub spacers
Posted: Sun Mar 25, 2018 10:34 am
Hi,
Couldn't find a clear example in stickys book so...
Damper washers in my kit I have 8 washers- 4 wavy washers, 2 small normal thick washers and 2 slightly larger thick washers and 4 nylon nuts. On bottom stud mount if i split the washers evenly its too short for the nyloc to fit properly.
Is stud, damper, thick washer, nyloc correct sequence?
For front hub I appear to be missing something as the gap is too large between the disc links. Anyone have a good pic of the assembly of the LH side?
Sent from my BND-L21 using Tapatalk
