Anyone found a turn signal switch for a S3?
Davidsquaredson
Main scooter: Early Eibar Jet 200
Hi, I have a Servetta with turn signals and it has a small switch box that attaches to the two holes to the left and below the light switch. I want to add indicators to my other lambrettas but this Servetta part has never been reproduced. I don't want to rewire the light switch for the indicators.
If someone has got a good solution I'd appreciate a photo of it.
David
carpe scooter diem
1974 Rally 200
1965 Li150
1963 TV175
1974 Eibar Jet200
Grumpy225
I have one of the serveta ones you're talking about.
The switch its self is really just a 2 position toggle with an off (ON OFF ON) and the bracket is literally a bent piece with 3 holes drilled in it. I'll dig it out and post some photos later today. It would be very easy to remake that your self.
Here's the switch if you want to build one your self.
https://www.delcity.net/catalogdetails?item=27300045
and here's the drawing of what it looks like and how you would wire it up
https://www.delcity.net/images/linedraw ... 0424182803
The bracket is just a L
Totally Scooters had a couple of the switch shells listed on eBay
Item 391993369636
I was thinking about making a small bracket to fit there and mounting one of these
Item 391738947703
It was for my non indicator Lince but I found a CEV 195 switch in the shed which is the one that goes in the gear change side.
    Users browsing this forum: No registered users and 37 guests
