60x115 Crank Kit Options
Lamaddict
Trying to run a Suzuki 185 piston on a TV175 barrel, it’s not working out too well.
Any options out there for that crank set up? Thinking Mugello 185 or BGM etc, don’t fancy an RB20
Rich_T
Main scooter: Li Special
You can run a GT186 on a 60x115 rod. You'll need 8mm packing but the cylinder is 3mm shorter than stock so it will all fit under the cowlings, worst case is to make a 5mm packer between between head cowling mag flange.
