BN266 or AV266 atomiser?
Posted: Thu Jul 16, 2009 1:48 pm
by ove
HI all, two questions for you all,firstly what is the difference if any in a BN atomiser and a AV atomiser?
Secondly can a BN be used instead of a AV atomiser?
Set up will be 186mugello 42mm clubman,28mm PHBH carb Li150 gearing .
cheers for any help.
Re: BN266 or AV266 atomiser?
Posted: Fri Jul 17, 2009 11:24 am
by RinB
Never used a BN type
could be used maybe, but would need to try it & see, but be careful
Would need to check against AV to see differences
Typicaly Differents, atomising hole sizes & hieghts, plus tube length may vary
Id sooner put in the AV as these are very widely used on Lamies & known to work well
Smiffy
Posted: Sat Jul 18, 2009 9:46 am
by Stokie
RS carb then ?
Posted: Sat Jul 18, 2009 12:37 pm
by ove
Stokie wrote:RS carb then ?
??? Second hand Dellorto PHBH 28, came with a BN266 atomiser. could it be a RS one??
just wondering if i could use the BN or would i have to buy a AV? Guessing i might have to buy the AV.
cheers.
Posted: Wed Jul 22, 2009 11:44 am
by jonny snatchsniffer
my mate has a bn266 in his 28 dellorto, might be how they come, tho his is on a vespa it runs good tho it had to have the tube shortened a couple of mm as it was running with a 74 pilot, now on a 55
