How to remove speedo drive if nut is burred
Posted: Fri Feb 23, 2018 1:53 pm
by Snails
Any suggestions on how to do this?
Re: How to remove speedo drive if nut is burred
Posted: Fri Feb 23, 2018 2:18 pm
by LI150
Mole grips
Posted: Fri Feb 23, 2018 5:35 pm
by Tractorman
Use a little heat on the hub and then grips as WTF??? suggests
Posted: Fri Feb 23, 2018 10:04 pm
by rosscla
Or file the burs off till you can get a spanner on it
Posted: Sun Feb 25, 2018 10:52 am
by Snails
Mole grips are just ripping the soft brass to bits. It's jammed so tight I think the resistance is always going to be greater than the force the nut can take. Ive been trying heat as well from the start
Last desperate idea is to run a drill down the centre and hope that I can weaken it enough before I destroy the thread. Seems unlikely though
Posted: Mon Feb 26, 2018 2:45 pm
by Snails
Got it in the end, before I broke it which was nice
a load of oil, 30 mins in the oven and getting the grips as tight as humanly possible helped a lot :D
