Kingwelle 64mm crank
Posted: Tue Jan 23, 2018 6:33 pm
by hungdog
Anyone know if any alterations are required to the casings when fitting a 64mm crank ?
Re: Kingwelle 64mm crank
Posted: Tue Jan 23, 2018 7:13 pm
by garry inglis
depends wich crank you use to how deep a groove is needed as some cranks big end runs insde the webs and others protrude
Posted: Tue Jan 23, 2018 7:53 pm
by hungdog
Vespa Kingwelle 64mm crank for P2 more worried about web size and possibly having to machine cases to fit webs than worrying about the rod making contact.
Posted: Tue Jan 30, 2018 8:10 am
by Ginch
They are usually pretty quick to reply on Facebook, worth asking them.
Posted: Tue Mar 06, 2018 6:12 pm
by hungdog
Kingwelle's reply
The motor has to be spindled up to 100.00mm , the crank diameter is 99.3mm
