Flooded Carb Box
Posted: Sun Jan 14, 2018 6:41 pm
by Tony Hart
Had what I thought was a soft seize on my wife’s autolube PX125. Got it going again by taking plug out and letting it cool before limping it home. Plug was very dark! Just had a look today and the carb box was full of 2stroke. Stripped the carb and box off engine and there was 2 stroke sat on top of reeds as well. Obviously a problem with autolube system but would appreciate any advice where I should be looking for cause and cure!
(Will also check piston & barrel! )
Re: Flooded Carb Box
Posted: Sun Jan 14, 2018 7:41 pm
by Shaunbond
Sounds like carb gasket has failed, the two stroke is just getting pumped into the box. Also check the pump gasket, they're usually less problematic but same result
Posted: Sun Jan 14, 2018 8:21 pm
by Tony Hart
Cheers. I’m hoping it is just the gaskets. Will swap them and see how I get on.
