Page 1 of 2
Backfire
Posted: Tue Jan 09, 2018 4:17 pm
by Steveshipley
Hi, one of my engines is playing up a bit. Starts and runs well but occasionally backfires. I can't pin it down to anything specific though. I changed the cdi, and also for other reasons swapped a 26mm jetex for a 26mm delorto some time ago, but I'm still getting the backfire. It's an early (2005 ish) mugello 186, not done a huge mileage and recently replaced rings.
Any ideas?
Cheers steve
Re: Backfire
Posted: Tue Jan 09, 2018 5:12 pm
by Daggs
The only time I've had that issue. It WAS the CDi !!
Re: Backfire
Posted: Wed Jan 10, 2018 6:33 pm
by drunkmunkey6969
Backfire is nearly always electrical. If CDI hasn’t cured it, you are going to have to investigate the other items. Pick the low hanging fruit first, spark plug, ht cap etc, but ultimately...it’ll probably be a pickup/firing problem.
Re: Backfire
Posted: Wed Jan 10, 2018 8:03 pm
by paulnobodyimportant
In my case, did Kelso this year and had great difficulty in starting. Lots of backfiring, bump starting then it would fire up, blew out smoke, but ok as revs rised. Changed CDI, plugs and checked new set of reeds. Next job was to check timing. That's when I found that the crank was twisted and running elliptical. This had caused the flywheel to wear down the contacts on the black trigger box. All sounds a bit extreme, but that was the cause of my backfiring. But as others have said, it will be a problem on the ignition circuit. Good luck.
Re: Backfire
Posted: Wed Jan 10, 2018 8:09 pm
by holty
i would guess at pick up or low tension coil, might be worth converting to one of anthony tambs external pick ups, a good upgrade.
Re: Backfire
Posted: Thu Jan 11, 2018 9:56 am
by Steveshipley
I've got one of Anthony Tambs stators spare so I'm just going to try swapping the whole stator.
Many thanks chaps.
Re: Backfire
Posted: Thu Jan 11, 2018 2:32 pm
by Adam_Winstone
One of the first things to check is whether the woodruff key has sheared, which allows the timing to go out, hence the misfire.
Adam
Re: Backfire
Posted: Thu Jan 11, 2018 7:59 pm
by mick1
Electrics would be my first port of call but don't rule out a fuel issue. My mate's Avanti always gives a little backfire before going onto reserve.
Re: Backfire
Posted: Sat Jan 13, 2018 8:27 pm
by psychedelicropcircle
Low tension coil 99- 100
Re: Backfire
Posted: Sun Jan 14, 2018 12:53 am
by Adam_Winstone
^... that's not good but reasonable for a pickup but for an LT coil that is bin time!
