PX leaking oil through breather nut
Posted: Fri Jan 05, 2018 9:42 pm
Asking for friend
PX was pushing oil out the breather when the engine warmed up oil level was correct.
Initially thought could be clutch side oilseal leaking air and building up pressure inside engine, hence pushing out oil once pressure reached.
Checked the engine, stripped and rebuilt replaced all bearings, seals new clutch plates and springs plus had the crank balanced again Now when the engines has warmed up the oil is pouring from the breather again.
Any help or advice would be appreciated thanks
