Is This Knackered?
Posted: Sat Dec 30, 2017 9:15 pm
I think I know the answer already, but would you re-use this 4th gear?
As you can see, there's a lot of wear leaving just a ridge instead of a flat surface. The shaft is also a bit worn on the opposing surface and probably explains the 0.5mm play on the gears.
What do you think would case this, lack of oil perhaps?
It's come out of a 150 series 2 that I'm pulling apart for some winter fun.
Thanks,
George.
Thanks,
George.
