Piston and Ring Clearance
Posted: Wed Dec 13, 2017 4:12 pm
by Lamaddict
Just have TV barrel rebored for Suzuki TS185 piston. The guy honed it for 3.5 thou clearance between the piston and the barrel but now I’ve put the rings on the piston will hardly go into the barrel. Should the clearance be between the rings and the barrel, any other suggestions?
Re: Piston and Ring Clearance
Posted: Wed Dec 13, 2017 4:36 pm
by bazza3004
Have you checked the ring gap. Push the ring/rings in to top of cylinder a couple of cm using piston crown and make sure you have the required ring end gap by checking with feeler gauge. Cant recall what this should be on a cast barrel but sure some one will tell you. You may need to gently file the ring ends to achive this.
Posted: Wed Dec 13, 2017 4:53 pm
by Lamaddict
Checked the ring gap at the top of the barrel and that was fine. I’m thinking the Suzuki TS185 pistons with the rings on needs a larger clearance than normal. It all just seems a bit odd.
Posted: Wed Dec 13, 2017 4:59 pm
by HxPaul
Are you putting the piston rings over the top of the ring pegs.
Posted: Wed Dec 13, 2017 5:49 pm
by Lamaddict
Rings are in the right place
Posted: Wed Dec 13, 2017 5:55 pm
by scooterslag
bad rebore maybe?
Posted: Wed Dec 13, 2017 6:32 pm
by garry inglis
3-5 tho sounds ok get some vernier callipers and measure spiggot end and top end as a rebore is different to a hone it could be out of shape
Posted: Wed Dec 13, 2017 10:36 pm
by HxPaul
I know it sounds improbable,but have you tried the piston without the rings.Maybe its to big.
Posted: Thu Dec 14, 2017 12:20 am
by Lamaddict
Okay, took it back to the shop. The rings were upsidedown
. Looking at the pin position and rings there was nothing to indicate a difference but he pointed out a small mark at the edge of the rings and that side faces the top of the piston. One to watch out for others using that type of piston.
Posted: Thu Dec 14, 2017 6:16 pm
by Lamaddict
Then I put the wrong crank, too much stuff laying about.
