Page 1 of 2
Master Cylinder
Posted: Tue Dec 12, 2017 10:00 pm
by rosscla
Looking at options for a master cylinder, am I right in thinking that most of those for 7/8" bars (22mm) will be 32mm between the centres on the mounting?
Anyone identify any good / neat alternatives to the huge bulky ones that come with most hydraulic conversions?
Re: Master Cylinder
Posted: Wed Dec 13, 2017 12:39 am
by cartmel808
These ones from Jockey’s are quite neat (but pricey)
http://www.jockeys-boxenstop.de/shop/en ... -3901.html
Re: Master Cylinder
Posted: Wed Dec 13, 2017 8:09 am
by storkfoot
Speedfight 100, made by AJS.
Re: Master Cylinder
Posted: Sat Dec 16, 2017 1:11 pm
by rosscla
cartmel808 wrote: ↑Wed Dec 13, 2017 12:39 am These ones from Jockey’s are quite neat (but pricey)
Yes, nice and they do one for Lince but I'm on a budget and trying to avoid LAT... ;)
Re: Master Cylinder
Posted: Sat Dec 16, 2017 1:32 pm
by rosscla
storkfoot wrote: ↑Wed Dec 13, 2017 8:09 am Speedfight 100, made by AJS.
Cheers
Re: Master Cylinder
Posted: Sat Dec 16, 2017 9:41 pm
by storkfoot
rosscla wrote: ↑Sat Dec 16, 2017 1:32 pm
Cheers
It’s AJP, not AJS. Mine was second hand 7 years ago and still going strong. Mine is mated to an MB housing on a GP though.
Make sure you get the 100cc version, not the 50cc if you go down this route. They are still fairly plentiful on ebay although there aren’t as many as a few years back. This makes me think I should get a back up too.
Re: Master Cylinder
Posted: Sun Dec 17, 2017 1:11 am
by rosscla
Ta, am looking for something to mate to this bracket -
https://www.beedspeed.com/lambretta-bra ... 12394.html
As I do not want to cut up the original lince switch support.
Re: Master Cylinder
Posted: Sun Dec 17, 2017 11:57 am
by storkfoot
Sorry. Mine is 35mm give or take a centremetre although, as with everything, you could probably fettle it to fit.
Re: Master Cylinder
Posted: Sun Dec 24, 2017 3:40 am
by corrado
rosscla wrote: ↑Sun Dec 17, 2017 1:11 am Ta, am looking for something to mate to this bracket -
Those brackets are around £20 and generally don't fit very well without fettling, though once fettled they work fine and are solid. You can fit most 22mm type motorbike master cylinders on them to save money but they tend to be just as bulky.
The AJP type definitely has a slightly small reservoir but all the ones I could see on Ebay were more expensive than the Nissin type ones.
https://www.ebay.co.uk/itm/Master-cylin ... Swez5Zy7Mn
Re: Master Cylinder
Posted: Sun Dec 24, 2017 8:36 am
by storkfoot
corrado wrote: ↑Sun Dec 24, 2017 3:40 am
I searched under Peugeot Speedfight 100 master cylinder ;-)
