Mag flange
Posted: Fri Nov 17, 2017 6:10 pm
by cgt75b
Hi peeps
One of the threads has gone on the mag flange where the stator fixes too it.
What's the easiest fix?
Cheers for any help.
Re: Mag flange
Posted: Fri Nov 17, 2017 7:18 pm
by bristolmod
a bodge is to drill and tap just close to the knackered thread.
Re: Mag flange
Posted: Fri Nov 17, 2017 7:23 pm
by Steve t
Helicoil kit cheap enuff from eBay and easy to do in ally
Re: Mag flange
Posted: Fri Nov 17, 2017 7:50 pm
by garry inglis
Or tap out to m7 and put a 7mm dome head bolt in
Re: Mag flange
Posted: Fri Nov 17, 2017 8:44 pm
by Scooterdude
I'd use a timecert, failing that a helicoil.
Re: Mag flange
Posted: Fri Nov 17, 2017 9:15 pm
by Grumpy225
cgt75b wrote: ↑Fri Nov 17, 2017 6:10 pm Hi peeps
Other than the 2 M6 threaded holes for removing the mag flange there aren't any other threaded holes where the stator sits.
Regardless, any stripped thread can be fixed with a helicoil or timesert. The trick is making sure it goes in straight.
Re: Mag flange
Posted: Fri Nov 17, 2017 9:38 pm
by cgt75b
Cheers for the advice fella's I'm gonna go down the helicoil route I think.
Thanks.
Re: Mag flange
Posted: Fri Nov 17, 2017 9:39 pm
by cgt75b
Are the eBay kits any good? Because I've had some proper shite off their.
Re: Mag flange
Posted: Fri Nov 17, 2017 9:54 pm
by Grumpy225
I use these. Maybe Amazon or Ebay sells them.
https://www.threadkits.com/perma-coil/m ... /1221-306/
Easy to install and haven't had one fail yet.
Re: Mag flange
Posted: Fri Nov 17, 2017 10:28 pm
by HxPaul
cgt75b wrote: ↑Fri Nov 17, 2017 9:39 pm Are the eBay kits any good? Because I've had some proper shite off their.
Yes.I've used them a couple of times when the thread on the chaincase is stripped (the one that holds the tailpipe bracket of the exhaust)
