Page 1 of 2
Garage door security
Posted: Tue Oct 31, 2017 6:44 am
by Simonwwfc26
What's do you guys use to help secure you garage main doors
I've already got four hd live cctv cameras
on my property linked to my mobile phone with perimeter settings , been looking at a door defender that's bolted into ground ?
Re: Garage door security
Posted: Tue Oct 31, 2017 8:19 am
by drunkmunkey6969
If you can close it from the inside and exit through a side door... Just drill 3 holes in the base of the door which run into the floor of the garage...and drop long metal bolts in them.
Posted: Tue Oct 31, 2017 8:32 am
by Simonwwfc26
Thanks dan yes my garage is built on the side of the house . At present I’ve drilled the frame and stick a mild steel bolt through a hole but would like to beef it up
Posted: Tue Oct 31, 2017 9:05 am
by Muttley McLadd
Maybe if people could post photos of their security arrangements, that'd be a good idea.
Obviously not switching off the location information on their photos first.
Posted: Tue Oct 31, 2017 9:33 am
by HxPaul
I've got an "up and over" garage door,it was secured originally by the door lock in the middle,I have put a padlock and hasp at the bottom and top of the door and I have an alarm inside.I have also a c.c.t.v.system that is recording 24 hours a day.
Posted: Tue Oct 31, 2017 11:20 pm
by Meds
I use one of these
https://www.screwfix.com/p/squire-garage-defender/79478
And park the car so they can't get at it easily.
It's not foolproof - but it's a decent start.
Posted: Wed Nov 01, 2017 8:55 am
by bristolmod
HxPaul wrote: ↑Tue Oct 31, 2017 9:33 am
same here re the hasp and shackle- as long as you fix it so the bolts are covered by the hasp when locked.
I use a heavy duty H&S big expansion bolts and a quality padlock. The scooter is down the far end, then I have my car in the garage; the locked and H&S door; then my wifes car. Intruder lights outside
Oh....and a 12 bore......
If they can get past that lot and live they can have it!!
Posted: Wed Nov 01, 2017 11:39 am
by Burnside
drunkmunkey6969 wrote: ↑Tue Oct 31, 2017 8:19 am
I like that idea, always dubious about external security devices as although they provide a visual deterrent they are also advertising that you've got something valuable inside.
Posted: Mon Nov 13, 2017 2:45 pm
by EddieStone
Most people have something valuable in their garage.
A work colleague had their garage broken into last week while he was on holiday. He lost three motorbikes, all his tools, windsurfers, sailing equipment and the CCTV system. One guy was caught, and it turned out the garage door was open all week and loads of people must have helped themselves.
Securing the door to the floor seemed to be the best thing to do. Does anyone alarm their garage doors? If it's open and the alarm is going, someone might eventually show up to find out why.
I think a CCTV system might be a deterrent but pretty useless unless you enjoy watching re-runs of your stuff being nicked by fuzzy people with their faces covered
Posted: Mon Nov 13, 2017 3:44 pm
by GeorgeS
My sister worked on a property where on outbuildings they had a wire connected to the door that when opened pulled a pin out of a scaffold tube allowing a shotgun cartridge to full down the tube on to a nail. You had to disable this before opening the door in full.
Bit of a one-off-noise kind of alarm, but hopefully enough to scare off the herbert snooping around.
