Sito plus or Scootopia Big Bore ?
parky
Further to my previous post regarding changing the exhaust on my LML 2T which is kitted with a DR180 kit. I have been very happy with the Sito Plus exhaust which has now died. Therefore I need to purchase a replacement and have noticed that Scootopia make a big bore exhaust which is quite a bit cheaper than the Sito Plus. I was wondering how the two exhausts compare? Should I stick with the Sito or would I get a similar performance from the Scootopia Big Bore and save a few quid? All suggestions welcome...
There's a plethora of box pipes available these days. Is there a reason you've shortlisted just these two?
brucie
Main scooter: vespa px mk1
Used to have a sito plus on my t5 until it fell apart changed to a bgm big box. Very good fit and added a couple of miles to top end.
Scootering did a big box test in 2016, Https://www.scootering.com/the-vespa-bi ... aust-test/
parky
I really want to stick to a standard looking box and both the Sito plus and the Scootopia seem to suit. It is also a matter of cost which I am trying to keep down as far as possible. As I said previously I was happy with the Sito but if the Scootopia would give me the same or similar performance then I would be more than happy to go with that. So I am hoping someone could confirm what the Scootopia performance would be like compared to the Sito plus. All suggestions welcome.
Shaunbond
If you haven't done already this is worth a read. Albeit on Px200 it gives you an idea of what each pipe does or doesn't provide.
https://www.scootering.com/the-vespa-bi ... ust-test/
    Users browsing this forum: Google Adsense [Bot] and 9 guests
