Malossi 210 exhaust options
Posted: Fri Oct 27, 2017 2:09 pm
by poose
Im currently running a malossi 210 kit with 60 mm crank with 26 mm standard type carb and a taffy pipe, all casings have been matched. Still running it in but looking to put a more standard type exhaust on like a sip road 2 or BGM sport or clubman . Im looking more for a good spread of power with quick acceleration rather than top end speed any recommendations
Re: Malossi 210 exhaust options
Posted: Sat Oct 28, 2017 1:29 am
by ricalnic
Love my 210 on it's Taffy pipe, interested to see what you end up with. I cannot compliment the Taffy enough, she crisp and revs out with a lovely top end rush.
Posted: Sat Nov 04, 2017 7:50 am
by Ginch
I'm running a 210 Sport with 60mm crank and SIP road. Tons of torque. Very happy with it.
I did have a 24/24 but recently went reed/PWK. Both setups worked well with the exhaust.
Posted: Sat Nov 11, 2017 8:42 pm
by poose
Thanks Ginch I think its the way I will be going as would sooner have easy access to my rear wheel which the Taffy restricts.
Posted: Sat Nov 11, 2017 8:47 pm
by rosscla
Which reed and PWK did you go with?
Posted: Mon Nov 13, 2017 9:27 am
by Ginch
rosscla wrote: ↑Sat Nov 11, 2017 8:47 pm Which reed and PWK did you go with?
I was given an MMW1. It's out of production now but the reed sits at 45 degrees rather than horizontal... so not quite as straight a run as the later ones. The carb is an OKO I got very cheap. Seems to work well enough but a Keihin is on the list for the future. Interestingly the OKO has 30 marked on the side. Measures 29.5 at the widest point and 28 at the smallest! :lol:
Posted: Fri Feb 23, 2018 3:24 pm
by rosscla
I have seen them offered as 28/30 in some places the bore is supposed to be a bit oval
