Page 1 of 2
Lambretta small block Port Maps
Posted: Fri Oct 20, 2017 8:12 pm
by johnny650
I tried my hand at producing a port map of my 200cc small block cylinder before fitting it and as it turned out quite well I thought that it might be useful to someone else.
It could prove a useful starting point for porting other small block cylinders perhaps?
I'd be interested to see your small block port maps or hear any observations or opinions on the porting of this cylinder . This cylinder was part of an Indian cylinder kit I purchased several years ago so I have no information about it unfortunately.
After much faffing about with bits of paper, scissors and sellotape without success I applied a bit of commonsense and devised an easy foolproof method. ;)
Using 2*Pi*R to find the internal circumference of the cylinder so a 66mm bore gives approx 207mm and the cylinder is 128mm high so cut a piece of paper 207mm x 128mm and join together the short sides with a narrow strip of sellotape to form a cylinder with perfect fit ...simples
175cc cylinder bore 62mm = 194.8mm
186cc cylinder bore 64mm = 201.1mm
Why not have a go with your spare barrels
Image200cc original port map by John, on Flickr
Re: Lambretta small block Port Maps
Posted: Sat Nov 18, 2017 9:25 pm
by johnny650
nothing much to do today so I thought I'd amuse myself with doing another port map.
I've searched the web but not found a single small block port map anywhere.
Not sure if these are going to be helpful to anyone as despite several hundred views there hasn't been any feedback ?
At least it might give someone a starting point for porting from stock or guaging how much porting work has already been carried out on an unknown barrel.
Problem is I have no idea of the vintage or manufacture of this cylinder
ImageTV 175cc port map by John, on Flickr
Posted: Sun Dec 03, 2017 10:13 pm
by YAMLAM
Page Not Found
this is what i get from your link/photos
Oops! Looks like you followed a bad link.
If you think this is a problem with Flickr, please tell us.
Here's a link to the home page.
Posted: Sat Dec 09, 2017 11:47 pm
by johnny650
sorry yamlam there wasn't a single response to my posts so I assumed there was no interest so when I accidently deleted the images from my Flickr account the other day I didn't bother to upload them again.
What is your interest may I ask ?
Posted: Sun Dec 10, 2017 8:26 am
by hendy
I was interested
Posted: Sun Dec 10, 2017 9:42 am
by drunkmunkey6969
johnny650 wrote: I've searched the web but not found a single small block port map anywhere.
RB20 here...I’m sure BGM195 and a few others are on here somewhere too?
viewtopic.php?f=7&t=490&sid=ac58d1acc8d ... 1e3b4c3b6d
Posted: Sun Dec 10, 2017 10:02 am
by drunkmunkey6969
This was the RB200 specific thread: viewtopic.php?f=7&t=296&hilit=portmap
Posted: Sun Dec 10, 2017 10:38 am
by drunkmunkey6969
This was the OPs original map: Image
Posted: Sun Dec 10, 2017 7:51 pm
by johnny650
drunkmunkey6969 wrote: ↑Sun Dec 10, 2017 10:02 am This was the RB200 specific thread: viewtopic.php?f=7&t=296&hilit=portmap
yes I did see that RB20 but that is a special cylinder with reed valve not a standard ci small block 150 or 175cc barrel that has been bored to 195 or a lined aluminum Indian barrel .
Thanks for re-posting my image I'll reload my 175cc port map when I get a spare minute
Posted: Tue Jul 17, 2018 12:45 am
by johnny650
185cc port map done tonight . Thought I would add it to the others in case it is of any interest to someone.
ImageLambretta 185cc Port Map by John, on Flickr
