Only runs with choke on.
Posted: Fri Oct 06, 2017 7:55 am
by 10 inch Terror
Hi all, after being off the road for a while I’ve spent the last few days sorting out my RB250. I’ve replaced the rear hub bearing and seal and checked the 5 speed box and clutch. Other than that I’ve not touched anything else enginewise. It started within 15 kicks but revs quite high and will only run with the choke on. As soon as the the choke is off it dies and will only restart with the it on again. Can anyone advise please as I have an MOT booked for this afternoon. Thanks in advance Pete.
Re: Only runs with choke on.
Posted: Fri Oct 06, 2017 8:05 am
by GeorgeS
Sounds very much like an air leak to me, have a look around at the carb manifold, mounting rubbers and exhaust manifold. Hopefully it's one of those things rather than a crank seal.
Maybe also a blocked jet from standing?
Posted: Fri Oct 06, 2017 8:19 am
by 10 inch Terror
Ok cheers, I’ll whip the carb off 1st. Then check for leaks. It was running perfectly prior to going off the road. Thanks Pete.
Posted: Fri Oct 06, 2017 12:25 pm
by 10 inch Terror
I whipped the carb off and it was gummed up. A quick clean and it’s all good again. I love a happy ending.
