My Vespa P200e wants SAE 30 plain oil for mixing with gasoline - as do my other Vespas. It wants 90 weight gear oil for the transmission.
I have read that "they are the same" and "they are different".
I changed the oil in the gear box over the weekend, using 90 weight gear oil. When the engine is first started (cold start) gear shifting is very difficult. After it has warmed and several shift sequences have taken place, shifting seems normal. Oil level seems correct, just wanting to run out the uncapped fill opening.
So I am thinking maybe "they are different" is correct and I should have used the same oil I mix with gasoline. Here are the choices at hand, from stateside Walmart.
So is there an authoritative, definitive answer? Are they the same or different?
