Fibreglass ?
nellyboyo
Going to be attempting my 2nd spray job soonish....the orginal TV mudgaurd is fibreglass.
Is there anything I need to do differently when spraying this ?
Some people will tell you to use etch primer but 2k primer is all you need but give it a good going over with 240 grit or courser to give it a good key. 2 coats of 2k primer will fill sanding marks up to 80 grit.
nellyboyo
Tidy mate , thanks for that
