Af road clutch won't disengage
Posted: Sun Sep 17, 2017 4:32 pm
by Bensmith225
Fitted an af road clutch yesterday and when it was all back together I can't compress it at all, the cable is moving freely and it's not trapped behind the shock. I have no idea what's causing it but before I split it open again I'd like an idea of what's causing it
Sent from my iPad using Tapatalk
Re: Af road clutch won't disengage
Posted: Sun Sep 17, 2017 6:07 pm
by garry inglis
If it's a gp casing did you fit the brassplunger the right way round and did you try it for smooth operating and sometimes you need to file it down a bit and did you fit the top cap weather it's gp or li witch has a nipple on
Posted: Sun Sep 17, 2017 6:11 pm
by Bensmith225
You've got me thinking about the plunger now as it did drop out while I was fitting the casing I guess it is possible I put it back in the wrong way round , the plates slid into the crown wheel nicely and the top cap is in it
Posted: Mon Sep 18, 2017 10:25 am
by dapper
I had a similar problem and found that the christmas tree was too tall, stopping the centre button from moving inwards at all. Changed Xmas tree and all fine.
Posted: Mon Sep 18, 2017 10:27 am
by Bensmith225
That could be the case, I put a new box in when I fitted the clutch I suppose I could grind the tree down to give me more clearance
Posted: Mon Sep 18, 2017 5:43 pm
by Bensmith225
Took it to bits, the plunger was fine and the plates move freely so I'm guessing it's the nut and Christmas tree
Posted: Mon Sep 18, 2017 7:08 pm
by alanscottj
I had the same problem - took about 2mm off the Christmas tree and worked spot on :D
Posted: Mon Sep 18, 2017 7:10 pm
by Bensmith225
It was the nut all along! Just shaved it and it moves in and out nicely with the clutch compressor
Posted: Wed Sep 20, 2017 11:56 pm
by corrado
Bensmith225 wrote: ↑Mon Sep 18, 2017 10:27 am That could be the case, I put a new box in when I fitted the clutch I suppose I could grind the tree down to give me more clearance
Ben at Rayspeed said that should cure it, when Chiselspeed stronger springs were used.
Posted: Wed Sep 20, 2017 11:58 pm
by Bensmith225
It's all sorted out now. Operates properly and once it beds in it should stop being so snatch
