Rear Hub Cone
Lamaddict
I've got a Servetta hub to go onto an Italian layshaft but I've lost the Servetta hub cone. Will the Italian cone work?
Lamaddict
Anyone?
hendy
I guess it depends on the cone angle. There are three that I'm aware of. 8, 10 and 11 degrees I believe. They need to match.
Measure the diameter top and bottom of the cone and the "hole" in the hub and work out the angles of both.
Warkton Tornado No.1
Main scooter: Lambretta SX200
I wanted to physically check before saying anything, because, prior to doing so I looked @ both RLC & SR's sites which confused me.
I've just checked seven spare cones that I could find against three hubs, one being Innocenti SIII & the other two Serveta 'strong type.
Of the four greater included angle cones, they all went in the Innocenti S III hub.
The three shallower included angle cones all went in the Serveta.
However, I can only stress that they were my findings & I've only felt that I should contribute to this Post because it is a safety critical issue.
Whatever you decide, you really should lap the cone into the hub using grinding paste because that will confirm whether you have a matching set, or not.
Lastly, try & get a cone that is 'hard' as the last few that I've bought specifically for Serveta hubs have not been & look like they've been splined in the bore after minimal use! So, my advice is to avoid one of the obvious sites & ask a Serveta specialist parts supplier, as I wish I had done.....
Warkton Tornado No.1 wrote:I wanted to physically check before saying anything, because, prior to doing so I looked @ both RLC & SR's sites which confused me.
Sounds like basis for an interesting article...
