Gearbox rebuild kit
Posted: Fri Sep 08, 2017 11:13 am
by Geocamper
Looking for suggestions as to the best quality bearing gearbox rebuild kit.
Re: Gearbox rebuild kit
Posted: Fri Sep 08, 2017 12:46 pm
by HxPaul
In my opinion Japanese Koyo bearings are the best you can get.I'm a bit confused as to which bearings you want,is it the endplate bearings,gearcluster needle roller bearing,or the rear hub bearing.
Posted: Fri Sep 08, 2017 3:30 pm
by fluff34567
Simply go to a bearing dealer and choose your own bearings. All the gearbox needle roller cages will be INA and then you decide is you want SKF FAG NACHI etc.
Be aware I know of 1 dealer that claims to supply INA bearings in the kit but those supplied are totally different to an INA in a stamped sealed box.
Posted: Fri Sep 08, 2017 6:52 pm
by Geocamper
I'm looking at purchasing all the bearings to rebuild the gearbox of a series 2 150.
Sent from my SM-G900F using Tapatalk
Posted: Fri Sep 08, 2017 8:32 pm
by Scooterdude
Ive used Scootopia rear hub bearings in the last couple of builds, they seem pretty decent. By contrast the indian ones sold by AF are dire.
Posted: Sat Sep 09, 2017 12:22 pm
by rosscla
For the rear hub next time I'm going to use the LTH, that way you can fit a standard sized quality bearing in the back end.
Posted: Sat Sep 09, 2017 3:47 pm
by Scooterdude
rosscla wrote: ↑Sat Sep 09, 2017 12:22 pm For the rear hub next time I'm going to use the LTH, that way you can fit a standard sized quality bearing in the back end.
Yes I've found a used hub bearing that is in two parts so you can put for example a standard SKF bearing in this outer carrier, neat idea but overall the actual bearing is quite a bit smaller.
Posted: Sun Sep 10, 2017 7:26 pm
by fluff34567
Jockey's sell the same
Posted: Sun Sep 10, 2017 9:52 pm
by rosscla
fluff34567 wrote: ↑Sun Sep 10, 2017 7:26 pm Jockey's sell the same
That's the one I meant, sorry confused LTH and Jockeys
Posted: Tue Sep 12, 2017 10:43 am
by fluff34567
I found the housing material very soft so beware.
